CCher9
6 years agoProgram Problem with EP3C40F484I7 FPGAs
Hi Our design includes the following: FPGA: Two EP3C40F484I7 Config: One Numonix RC28F128P33T85 Scheme: Byte-Wide Multi-Device AP Config Master MSEL(3:0)= 0101b Slave MSEL(3:0)= 1110b Progr...
NurAiman_M_Intel
6 years agoHi,
Is .jam file generated when you were compiling program or you created the .jam file using quartus programmer?
Can you try create .jam by using quartus? Kindly follow steps in the link below:
https://forums.intel.com/s/question/0D50P00004cG4Zu/advanced-jbc-files-with-normal-compilation-flow
Thank you.
Aiman
