CCher9
6 years agoProgram Problem with EP3C40F484I7 FPGAs
Hi Our design includes the following: FPGA: Two EP3C40F484I7 Config: One Numonix RC28F128P33T85 Scheme: Byte-Wide Multi-Device AP Config Master MSEL(3:0)= 0101b Slave MSEL(3:0)= 1110b Progr...
NurAiman_M_Intel
6 years agoHi Chaim,
Please clarify below:
- Have you follow the guide available in below userguide?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/AN425.pdf
2. If you have follow the user guide, how did you generate .jam file?
3. Which command-line executable that you are using?
Are you using jam STAPL players?
Thank you.
Aiman
CCher9
6 years agoHi Aiman,
1. Clarification:
1.1 Yes, we have follow the AN425.
1.2 We did generate .jam file from .pof file by Quartus II.
1.3 JTAG Technologies using jam STAPL player (with .jam file).
2. We performed additional tests:
2.1 We run Jam STAPL Player in DOS Command Window, using ByteBlasterMV.
The commands were:
For configuration: jam.exe -v -aConfigure -p378 config.jam >>stat.txt
For programming : jam.exe -v -aProgram -p378 config.jam >>stat.txt
2.2 When the programming was successful we got the following status - see attachment stat -1.
When the programming failed we got the following status - see attachment stat -2.
Note: The programming never failed in the middle of the process, only at the beginning.
2.3 With Quartus II + ByteBlasterMV we haven't any problem to program.
Pls advice,
Thank You,
Chaim
