16 years agoProblems with the pin assignment
Hi to all, first of all, I'm using the Cyclone III EP3C25F324 FPGA. I created an new external board with a radio chip on it and some other peripherals. I have connected the FPGA to my external ...
16 years agoHi, thanks for your fast reply.
Yes, the signals HSMC_SDA and HSMC_SCL are outputs of my top level design. I have tried to assign the pins E1 to the HSMC_SDA and F3 to the HSMC_SDA signal in the assignment editor, but it still doesn't work. I only got a high or low level on my pins. It depends on which default values are choosen in the pin properties window. Instead of recieving signals I got the logic levels... Maybe I have to enable the pins first?
