18 years agoProblems with pin assignments with Cyclone III starter board
Hello, I have been attempting to program my FPGA to communicate with the SSRAM provided with the cyclone 3 starter board. However, when I attempt to assign pins H3 (FLASH_SRAM_DQ0) and D1 (FLA...
18 years agoThanks again, but I appear to continue encountering the same problem despite these changes. I have tried changing the configuration to passive serial as suggested and had the very same errors. When I attempted to change the configuration to active parallel I got these errors for multiple pins including the two problem pins. Is there something else that i am missing? Thanks.
Andre
