18 years agoProblems with pin assignments with Cyclone III starter board
Hello, I have been attempting to program my FPGA to communicate with the SSRAM provided with the cyclone 3 starter board. However, when I attempt to assign pins H3 (FLASH_SRAM_DQ0) and D1 (FLA...
18 years agoThe said pins are pins used by the AS configuration interface, apparently you enabled AS configuration and reserved the pins. AS configuration isn't used by the starter board.
