16 years agoProblems with NEEK tutorial using Quartus 9.1sp2
I will apologize in advance for being a NOOB... (perhaps, I should RTFM, too)
I downloaded the NEEK tutorial from Altera's website. The NEEK tutorial seems to be targeted at Quartus 9.0. Following the tutorial, I had no problems with the hardware portion of the tutorial -- I created the bit file just fine thanks. However, the menus for the software portion of the tutorial on Quartus 9.1sp2 were entirely different from the sceenshots in the tutorial. I was able to stumble through most of the differences but it seems that SYSLIB has become BSP. When I build the software application, the main program fails to compile since it is missing the uCOS stuff. Is there a newer tutorial somewhere? Can anybody straightened me out here? Looking through the Wiki, I did find a BSP with a uCOS directory in it. Thanks for the help, Wayne2 Replies
in 9.1 Altera switched to Nios II SBT (plugins) for Eclipse rather than a customized Eclipse release (Nios II IDE).
try searching altera.com for SBT tutorial and you'll find a couple of documents to guide you. - Altera_Forum
Guru, thanks for the help; it's really appreciated. Although you can't see me, I am bowing in your general direction.
