18 years agoProblems with Cyclone III - NIOS II Embedded Evaluation kit
Hi everyone, I just received my Cyclone III devkit last week, and this weekend I spent some time trying to get it to work. I still haven't had any luck. Hopefully, someone here can point me i...
18 years agoIt looks like that weird error was indeed due to the spaces in my path. Here's what happened once I fixed that problem:
- I created a new project in the Nios II IDE again, based on the binary counter template. This time, it built successfully - I then went to run as hardware, and got the following message in the IDE log: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x00021048: ID value does not match: read 0x00FFFFFF; expected 0x064BB6F8 Timestamp value does not match: image on board is older than expected Read timestamp 21:20:15 1970/07/13; expected 9:28:00 2008/03/25 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor I went ahead and added the .SOF file anyway at the programming screen, and when I clicked Start, it downloaded the program. The only thing that happened was my screen slowly turned all white, and all of the LEDs were on. For a binary counter project, I was expecting to see the LED states count up in binary, but they didn't.
