18 years agoProblems with Cyclone III - NIOS II Embedded Evaluation kit
Hi everyone, I just received my Cyclone III devkit last week, and this weekend I spent some time trying to get it to work. I still haven't had any luck. Hopefully, someone here can point me i...
18 years agoThe warnings in Quartus are no problem.
Have you installed the usb-driver? Have you created a new project? Or only oppened the .c File? Here is the Link to the Altera driver information http://www.altera.com/support/software/drivers/dri-index.html Can you download the design into the FPGA with Quartus Programmer? In the NIOS IDE start a new Project C/C++ Application. In the next dialog you can choose the sample applications (count_binary template) and you have to choose your Quartus hardware design, which should be used for this software. Click finish and the project will be created. Now right-click on count_binary and choose in the opened menu System Library Properties and only activate Programm never exits and Small C Library. That's all. Now you can build your project. Download the hardware design into the FPGA and than Choose Run<Run Hardware. http://www.altera.com/literature/tt/tt_nios2_hardware_tutorial.pdf I think this tutorial can help you to run the sample application.
