17 years ago
Problems with Cyclone III - NIOS II Embedded Evaluation kit
Hi everyone,
I just received my Cyclone III devkit last week, and this weekend I spent some time trying to get it to work. I still haven't had any luck. Hopefully, someone here can point me in the right direction, because I've gone through the user manual and it isn't helping.
1. I powered up the board after inserting the included SD card, and nothing appears on the screen. The user manual says that I might have to press the reconfigure button twice, but that doesn't help. I have confirmed that the SD card does have the sample apps installed.
2. I then used the nios2-flash-programmer to reload the factory image .flash file. After doing that, I received the following status:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Checksummed/read 1069kB in 1301.0s
Erase not required
Programmed 1101KB in 0.0s
No change to device contents
Leaving target processor paused
I'm not sure why the target processor is paused, but I would bet that's why the application selector isn't running. :) Can anyone tell me how to fix this?
3. I cannot get any sample apps to run in Quartus II v7.2. Every time I try to compile a sample app, it gives me errors related to my license file not having support for SD_MMC_..., or other options. I have a free 150 day (?) license, and already pointed Quartus II at this license file. If I can't compile and run any sample applications, what good was it to even buy this devkit?
4. When I run the NIOS 2 IDE and try the hello_world sample application, it won't run because I don't have a JTAG connected. Do I really have to buy more hardware just to print "hello world"?
Thanks in advance for any ideas / suggestions!
