16 years agoProblems with altera_reserved_tck
I have a Nios II system with level 1 JTAG debug module and I'm having alot of problems with altera_reserved_tck. I've included the sdc constraints for the JTAG module suggested by the time quest cook...
16 years agoTime constraints applied to altera_reserved_tck haven't helped me to fix this problem.
In my case the problem solution was quite simple. After to added a constraint to NIOS clock signal, all my jtag errors (related with clock altera_reserved_tck) disappeared. Eg --- Quote Start --- # Clock constraints create_clock -name "MCLOCK" -period 20ns [get_ports {NIOS_CLK}] -waveform {0.000ns 10.000ns}# Automatically calculate clock uncertainty to jitter and other effects. derive_clock_uncertainty --- Quote End --- where NIOS_CLK is the pin name related with oscillator input. BR,
