16 years agoProblems using Cyclone III Dev Board and Bitec DVI daughter card
Hi, I'm working with Cyclone III Development Board and the Bitec HSMC DVI daughter card. I'm trying to get the loop through example from the Bitec website working - but it wouldn't. DVI...
16 years agoEDIT:
Did you ONLY remove the output pins from the schematic? opne the SOPC builder and remove one frame buffer only, it should not flicker. They suggest two frame buffers to peform clock crossing between your custom block and pixel in-out clock.
