16 years agoProblems uploading program into flash memory
Hi, I used the Nios II EDS sof2flash program in the Quartus II 9.1 Web Edition to convert a good/functional sof file to flash format. I attempted to use the Board Update Portal to load th...
16 years agoI had the same issue and got it resolved by an SR to Altera. There is an issue with the sof2flash utility in 9.1 which was resolved in sp1. But you need to add two more options than described in the dev.kit guide. Check this support solution:
http://www.altera.com/support/kdb/solutions/rd01152010_225.html If this doesn't work I suggest you submit an SR. Regards, Ove Brynestad
