16 years agoProblem with TREX-S2 fromTerasic
I have one Kit "TREX-S2 FPGA Module" from Terasic.
I have configured and download the Nios System, but I can´t download the software of the microprocessor. The console show this messages: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused Please, could someone help me with this problem? Thanks very much.2 Replies
Is it your own Quartus project, or did you use a standard sof file provided with the kit?
It seems that your CPU is inactive. It can come from a bad clock or reset signal, or because you don't have a license for the CPU and closed the Opencores window. - Altera_Forum
Thanks very much for your reply, but fortunately I could solve the problem.
I have some come under the folder "my documents" and this issue gives me several problems. I put everything under the folder "C/Altera/.." and now things work. Thank you very much.
