15 years agoProblem with the pin of the character LCD on Cyclone III FPGA Development Kit
Hi, I have a problem, i try to use the PIN of the character LCD for other input/output. And i have a problem, the output is at 0.9V for a low signal, and at 1.9 for high signal. I set the vo...
15 years agoWhere are you testing the voltage? Is this really the voltage on the fpga pin?
Maybe you are testing on LCD pin and you have a series resistor between. (this is just an idea, I don't know your board layout)
