16 years agoproblem with the data transmitted from ethernet
Hi all, I use tse to transmit the data to my 3c120 board, and my problem is that which output pins are the data transmitted, i see there is "fsa","fsd","enet_rxd[3:0]", what's their difference...
16 years agoThank you Jake! So the pin i mentioned like fsa is of no use if i want to access the data?
Another problem is that why the enet_rxd/enet_txd is a [3:0] one? that means the data is stucked at a 4 bit width?
