16 years agoproblem with the data transmitted from ethernet
Hi all, I use tse to transmit the data to my 3c120 board, and my problem is that which output pins are the data transmitted, i see there is "fsa","fsd","enet_rxd[3:0]", what's their difference...
16 years agoI assume you have the user's guide for the board. I think you're referring to this board:
ftp://ftp.altera.com/outgoing/devkit/cycloneiii_3c120_dev_kit-v9.0.2.exe The board uses a Marvell 88E111 10/100/1000 ethernet PHY. This uses a GMII interfaces. Looking at the example projects, these are the corresponding pins: // ethernet interface enet_mdc, // mdio clock enet_mdio, // mdio data enet_rx_clk, // receive clock enet_tx_en, // transmit enable enet_gtx_clk, // 125MHz transmit clock (for gigabit) enet_rxd, // receive data enet_txd, // transmit data enet_rx_dv, // receive data valid enet_resetn // reset (negated) Jake
