PedroJServian
2 years agoProblem with the clock of the 10M08SCE144
Good morning, colleagues, I'm designing an FPGA to make a dead time and minimum pulse program for PWM signals coming from a uC. I performed a testbench of the design of these entities and they worke...
- 2 years ago
internal oscillator has an only roughly defined frequency, datasheet says min. 55, typ. 82, max. 116 MHz. Measured 84 MHz corresponds nicely to typical value. Specifying a different value in component instantiation has no effects on hardware, only in simulation.
To understand why you see sine waveform on oscilloscope, we need to know about IO standard and probing details. Unloaded pin waveform is basically a square wave, I guess you have low drive strength (e.g. 2 mA) and high load capacitance, e.g. 1:1 passive probe or direct connected coax cable.
Farabi_Altera
1 year agoHello,
It is not recommended to use internal oscillator if you design requires accuracy timing. You can use PLL instead feed by external clock oscillator. This is more reliable.
regards,
Farabi
