17 years agoProblem with Terasic ADA daughter board
Hi, I have problem using the Terasic ADA daughter board with the Cyclone III starter kit. I used the ADA_utility tool in the CD trying to generate arbitrary waveform. The utility programs coming with...
16 years agoI have exactly the same problem.
I first burned the QB3_TOP.sof into my CycloneIII Starter Kit FPGA, and then ran the ADA_Utility. But it gave a series of errors: a) Unable to locate component b) Load DLL Error c) Execute (NIOSDownloadBatch.bat) fail , ExitCode:1h d) Failed to find your board Meanwhile, it did detect my board-type correctly, in between ... still failed to work. Furthermore ... an interesting observation was that, I tried running this ADA_Utility.exe directly ... without burning the Quartus file into the FPGA - and there was no difference in its behaviour. Is this ADA_Utility even meant to work for the Starter Kit. Can somebody help ?
