14 years agoProblem with reading register of deo nano's accelerometer
Hello everyone,
I am using deo nano and am trying to read the register of its accelerometer via I2C. I have used the same program to read a value from eeprom register and it works out well. But using the same program, I cannot get acknowledge signal at the moment I sent the device address(accelerometer). I have checked my timing diagram and have generated a slower clock that pass with accelerometer. I also use signaltap2 to check out the value of my internal register. Here is the syntax: // ADXL clock= 400kHz or 2.5uS or 125 samples of 50mHz. // ADXL address= 0x53/1010011 (alt address pin grounded) module ADXL_Read( clk_50, //clock 50Mhz// key, I2C_sclk, I2C_sdat, ); input clk_50; input [1:0] key; output I2C_sclk; inout I2C_sdat; wire reset_n; reg GO; reg sdi; reg sclk; reg [6:0] count; // Create slower clock with 128 samples of 50Mhz reg [6:0] sd_counter; reg [6:0] slave_add = 1010011; // DEFINE SLAVE ADDRESS reg [7:0] register_add = 00110010; // DEFINE REGISTER ADDRESS reg [7:0] data; //Data that is read assign reset_n= key[0]; // 50MHz clock is too fast for the our devive(in this case eeprom), // therefore slower clk need to be generated always@(posedge clk_50) count <= count + 1; // key[0] is to reset the whole operation // key[1] is to give a start signal always@(posedge count[6] or negedge reset_n) begin if (!reset_n) GO <= 0; else if (!key[1]) GO <= 1; end always@ (posedge count[6] or negedge reset_n) begin if(!reset_n) sd_counter <= 6'b0; else begin if (!GO) sd_counter <= 0; else if (sd_counter < 52) //sd_counter maximum sd_counter <= sd_counter + 1; end end always@ (posedge count[6] or negedge reset_n) begin if (!reset_n) begin sclk <= 1; sdi <= 1; end else case (sd_counter) 6'd0 : begin sdi<=1; sclk<=1;end //START 6'd1 : sdi <= 0; 6'd2 : sclk <= 0; //SLAVE ADDR+Write(Control Byte) 6'd3 : sdi <= slave_add[6]; 6'd4 : sdi <= slave_add[5]; 6'd5 : sdi <= slave_add[4]; 6'd6 : sdi <= slave_add[3]; 6'd7 : sdi <= slave_add[2]; 6'd8 : sdi <= slave_add[1]; 6'd9 : sdi <= slave_add[0]; 6'd10 : sdi <= 0; //Write(0) 6'd11 : sdi <= 1'bz;//Slave ACK //SUB ADDR(WORD ADDRESS) 6'd12 : sdi <= register_add[7]; 6'd13 : sdi <= register_add[6]; 6'd14 : sdi <= register_add[5]; 6'd15 : sdi <= register_add[4]; 6'd16 : sdi <= register_add[3]; 6'd17 : sdi <= register_add[2]; 6'd18 : sdi <= register_add[1]; 6'd19 : sdi <= register_add[0]; 6'd20 : sdi <= 1'bz;//Slave ACK //START 6'd21 : begin sdi <= 1; sclk<=1; end 6'd22 : sdi <= 0; //SLAVE ADDR+Read(CONTROL BYTE) 6'd23 : sdi <= slave_add[6]; 6'd24 : sdi <= slave_add[5]; 6'd25 : sdi <= slave_add[4]; 6'd26 : sdi <= slave_add[3]; 6'd27 : sdi <= slave_add[2]; 6'd28 : sdi <= slave_add[1]; 6'd29 : sdi <= slave_add[0]; 6'd30 : sdi <= 1; //Read(1) 6'd31 : sdi <= 1'bz;//Slave ACK //Data read(DATA) //Data byte 1 6'd32 : data[7]= I2C_sdat; 6'd33 : data[6]= I2C_sdat; 6'd34 : data[5]= I2C_sdat; 6'd35 : data[4]= I2C_sdat; 6'd36 : data[3]= I2C_sdat; 6'd37 : data[2]= I2C_sdat; 6'd38 : data[1]= I2C_sdat; 6'd39 : data[0]= I2C_sdat; 6'd40 : sdi <= 1'b1;//Master ACK //Data byte 2 6'd41 : data[7]= I2C_sdat; 6'd42 : data[6]= I2C_sdat; 6'd43 : data[5]= I2C_sdat; 6'd44 : data[4]= I2C_sdat; 6'd45 : data[3]= I2C_sdat; 6'd46 : data[2]= I2C_sdat; 6'd47 : data[1]= I2C_sdat; 6'd48 : data[0]= I2C_sdat; //stop 6'd49 : begin sdi <= 1'b0; sclk <= 1'b1; end 6'd50 : sdi <= 1'b1; endcase end assign I2C_sclk = (((sd_counter >= 4)&(sd_counter <= 20))|((sd_counter >=24)&(sd_counter <=50)))? ~count[6] : sclk; assign I2C_sdat = sdi; endmodule Here are the pin planner assignment: I2C_sclk : F2; I2C_sdat : F1 ; clk_50 : R8 ; key[1] : E1 ; key[0] : J15 ; Here are the signaltap node(trigger cond): sd_counter(don't care), I2C_sclk(don't care), I2C_sdat(don't care), GO(Rising edge). Signal configuration for signaltap2: clock(count[5]), sample depth(1k), storage qualifier(continuous), trigger(sequential, pretrigger position, 1) Note: make the "bus display format" of node "sd_counter" to be "unsigned decimal" for the ease of viewing. I realize the problem happen when sdat at 6'd3 until 6'd9. Although I assign slave_add to be 1010011, it appears at the signal tap to be 1011011 Why does it happen? I realize it is too much to ask. Please someone help me find out the solution. I have stuck in this problem for the last 3 days and have yet no idea. Thank you so much for helping me.
