14 years agoProblem with Quartus II 11.0 Programmer detecting Altera Cyclone II DE2 Dev Kit
After tools -> programmer the Programmer these show up like in the attached image.
For hardware type, there is none other then ethernet blaster; and auto detect didn't work. Basically the Dev Kit does not want to be recognised by Quartus II v11.0 If any, these are observed and done:- Board is powered on
- Tested when switch is at RUN and PROG
- Restarted program
- Restarted computer
- USB is connected from USB BLASTERt port of the board to the computer
Dear ,
Go to device manager see if you can find USB Blaster II and update them If not Install USB Blaster II drivers and try it out.
