AKARP2
7 years agoProblem when I try to simulate pcie_avmm_dma example design for Cylone 10GX
When I run tcl scripts they can't find file pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_191_nz2pxji.sv. Please, advice Thank you
AKARP2
6 years agoHi,
I'm using the same sequence as you.
I am working with Quartus Prime Pro 19.2, system - Windows 10
In “ xxx_example_design/xxx_example_design_tb/ ip/xxx_example_design_tb/xxx_example_design_tb/
pcie_example_design_inst_board_pins_bfm_ip/sim/common/modelsim_files”
you can find line:
lappend design_files "vlog -sv $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS \"[normalize_path "$QSYS_SIMDIR/../altera_conduit_bfm_191/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_191_nz2pxji.sv"]\" -L altera_common_sv_packages -work altera_conduit_bfm_191"
And this file is absent in this directory.
Can you send it to me?
e-mail [email protected]
Thank you, Alex
