hon1
3 years agoProblem running MAX 10 - Single-Port Triple Speed Ethernet and On-Board PHY Chip Design Example
Hi, I tried to run the example (MAX 10 - Single-Port Triple Speed Ethernet and On-Board PHY Chip Design Example (intel.com)) on Quartus 18.0. When I generate HDL using Platform designer, I gotten the...
ZiYing_Intel
3 years agoHi hlseck,
If you see the Qsys Path error message carefully, you untick below parameters and you will find that your issue resolved.
Zi Ying
