hon1
3 years agoProblem running MAX 10 - Single-Port Triple Speed Ethernet and On-Board PHY Chip Design Example
Hi, I tried to run the example (MAX 10 - Single-Port Triple Speed Ethernet and On-Board PHY Chip Design Example (intel.com)) on Quartus 18.0. When I generate HDL using Platform designer, I gotten the...
ZiYing_Intel
3 years agoHi hlsleck,
I try run the example design that you mentioned by using 18.0 std. The design was compiled successfully and there is no error message from my side.
Can you share your .qar file? So that I can try debug the issue from my side.
Zi Ying
hon1
3 years agoHi ZiYing,
I have downloaded the files directly from the link (https://www.intel.com/content/www/us/en/design-example/714819/max-10-single-port-triple-speed-ethernet-and-on-board-phy-chip-design-example.html). I can compile the project on Quartus 18 standard edition.
It is when I use Platform Designer to open qsts_top.qsys, I got the error messages stated earlier. I attached screenshot below for your reference.
hlseck
