17 years agoproblem of ethernet interface test on Stratix II GX Audio-video Board test design
Hi, I use the document "Stratix II GX audio-video board test design guide rev 0.5" which is included in the development board's CD for interface test. I followed the intructions provided in 1.6 Et...
17 years agoOkay, well you are apparently using version 8.0 of the MAC. They've updated the driver and I'm not as familiar with it. However, I do know that they changed the way they do PHY detection in 8.0. I believe the user has to do a little more than before.
The message you are getting comes from the MAC driver: C:\altera\80\ip\triple_speed_ethernet\lib\sopc_builder\altera_triple_speed_ethernet\HAL\src\altera_avalon_tse.c line number 1,271 The first thing I would check is your MDIO interface to the PHY. The MAC provides 4 signals that get exported outside of SOPC builder for the MDIO interface. mdc - MDIO clock mdio_out - MDIO output data mdio_oen - MDIO output enable mdio_in - MDIO input data At your top level, you need to make sure these are correctly connected to your PHY. Typically you're going to have a single bidirectional signal to/from the PHY which is the mdio data input/output signal. If we assume this signal is called eth_mdio in your top level, then you would need some assignments like this:module top_module(
inout eth_mdio,
wire eth_mdio_out;
wire eth_mdio_oe;
assign eth_mdio = eth_mdio_oe ? eth_mdio_out : 1'bz; // high-impedance when not driven
my_sopc my_sopc_inst(
.mdio_out_from_my_mac(eth_mdio_out),
.mdio_oe_from_my_mac(eth_mdio_oe),
.mdio_in_to_my_mac(eth_mdio),
Jake
