16 years agoProblem in using PLL
Hi,I am using this chip Cdcs502 from Ti.I am running a 27Mhz crystal and connecting Capacitor load of 35pF ,with FS=0,the output is a clock pulse with 0.8 low and 2.1 high,i think this is fine.But th...
16 years agoAccording to the datasheet, CDCS502 has 32 ohm driver impedance. It should be able to drive regular capacitive loads. However I don't have the chip and check it's behaviour.
--- Quote Start --- with FS=0,the output is a clock pulse with 0.8 low and 2.1 high,i think this is fine. --- Quote End --- This is far from keeping LVCMOS level specification. Sounds like you connected a heavy resistive load to output, you should operate it basically unloaded.
