19 years agoProb in Writing Data to DDR using C Routine
Hi all, when writing data from .yuv file stored on PC to DDR SDRAM Memory using C routine(Data Capture Routine considering syncs) from NIOS II, i am not able to read data more than 32 pixels.Can a...
19 years agoAre you running the FPGA 'Logicware' is the factory default or have you modified the system. If you modified the system, be sure you have the DDR clock setting correct (it needs a slight phase shift).
Mike
