Power Sequence of Arria V GX (FPGA)
Hi there,
If there's currently no further requests, I am setting this issue to resolved.
By the way, we would appreciate it if you can take a moment to fill in the survey about this IPS case, which will be sent to your email. Your feedback is valuable and helps us improve our support quality.
Xiaoyan
- NM113 years ago
Hi Xiaoyan-san,
Thank you very much for your kind response.
Please allow me to check a little more as it is complicated.As per "Power waveform_20230405.jpg", "VCC_1V5_FPGA" ramp time is 200ms, so it exceeds the specified value of 100ms.
What is the effect by this exceeding?
Our prototype seems to be working fine so far.I received the following answer previously, what exactly is "device configuration to fail"?
> As you can see from the Figure 11-7 in the Arria V handbook, POR delay and Configuration time will follow the tRAMP. If tRAMP is not met, the I/O pins and programming registers remain tri-stated, which may cause device configuration to fail.
For example, does the FPGA not respond to input signals at all?Best Regards,
Naoki
