12 years agoPlease help with the error led turned red
Hi everyone, I think I just made a big mistake. I was trying to measure signals from HSMC port of Cyclone V using oscilloscope, and I suppose I touched two pins with a probe at the same time. This...
12 years ago --- Quote Start --- I have checked out the schematic of the header and it turned out there were 12V power supply pins aligned right next to the normal I/O pins. Obviously I have touched this pin with some normal pins and it have destroyed the I/O pins. --- Quote End --- Don't feel bad. I had a similar problem in the past; when probing a switch-mode power supply circuit with a scope, I shorted the 12V input power to the enable signal, and that enable signal was driven by a MAX II CPLD. The CPLD was destroyed, but luckily it was in a TQFP package, so I could just replace it. --- Quote Start --- But luckily enough, I could still program the FPGA through JTAG. And I found a solution by substituting the former used pins with others. But anyhow, some part of the development kit seems broken, with the error LED still flashing. --- Quote End --- I'm glad to hear your kit can still be used. Cheers, Dave
