Please, help me to correct verilog module for alarm temperature
- sisa7 years ago
Use the RTL design process to create an alarm system that sets a single-bit output alarm to 1 when the average temperature of four consecutive samples meets or exceeds a user-defined threshold value (set your own threshold). A 32-bit unsigned input CT indicates the current temperature, and a 32-bit unsigned input WT indicates the warning threshold. Samples should be taken every 5 clock cycles. A single-bit input clr when 1 disables the alarm and the sampling process. Start by capturing the desired system behaviour as an HLSM, and then convert to a controller/datapath. Write your Verilog code and download your program into FPGA. Set LED as your alarm indicator.
- sisa7 years ago
i had a problem that my load input not connected to reg_ld...can u help me? 0166801697 this is my phone number.
