Dt493
1 year agoPLD device EPM7032TC44
Hello 1.Kindly provide the programming manual for the device EPM7032TC44 . 2.The Device has 2 OE pins to communicate with I/O ports , does the device need both of them to be enabled or only one .Ki...
FvM
1 year agoHi,
OE function is described in datasheet, see appended image. Each output can be either unconditionally enabled or depending on OE1 or OE2.
You can als use Quartus to check which function can be implemented.
