14 years agoPIO to Memory to PCIe on Arria II GX
Hello, I'm sorry to ask you such simple things, but I'm nearly running mad.
My Problem is: I want to check the data of a 32 bit wide general bus. This bus has a clock of 50 MHz. My intention is to use the Arria II GX Development Kit to capture the Data into the memory and read them into my Computer via PCIe. I think I can expand the "PCI Express to External Memory Reference Design" with something that writes from PIO to the Memory. I used the QSYS Example (file: "A2gx125_qsys_pcie_gen1x4.zip" from Altera) to test the board, but I don't know how to continue. Please have mercy, normally I'm more into Hardware. I can do a little C and C++ but VHDL and FPGA's simply aren't my thing. It took me nearly a Month to get the Board to work somehow and run the "altpcie_demo" :oops:. Is there anyone out there who can help me a bit? This is how the QSYS-Project looks at the moment. I've only added the things beyond the blue line. Above the blue Line is the original QSYS-Project which transferd data from Memory to PCIe and otherwise:13 Replies
--- Quote Start --- Finally I made it!!!! (Somehow) I now have a design to write a generic 32-Bit Bus with clock, write-enable and reset to a FiFo and read the FiFo from my computer via PCIe. Thank You BadOmen for the advice. --- Quote End --- Hi Steffen,I have the same work to do and meet too many problems:((i , a green hand for PCIE) : when i open the demo"a2gx125_qsys_pcie_gen1x4"and add the fifo component like yours,i don't know what should i do next . Could you give me some guides?:oops: - Altera_Forum
I'm so sorry. I didn't watch this forum for half a year.
I'm a student and had some other studies to do in the summer semester. Do you still have the problem? - Altera_Forum
aha....O(∩_∩)O it was solved.
thank you all the same
