15 years agoPin location(s) doesn't show in .bdf file.
I'm working with a Stratix-III development kit (DK-DEV-3SL150N). I based my application on the one provided by the kit. With some modifications (through research), it seems to be working fine (i.e. e...
15 years agoOK, I found a solution. I cannot take full credit for it, because another post in the forum
(http://www.alteraforum.com/forum/showthread.php?t=25485) started the process. I don't think it's the best solution (mine), but it works. So, if anyone has a better solution, please advise. Here's what I did: 1. Created main.bdf file and make it the top-level entity. 2. Created symbol file from stratixIII_3sl150_ dev_niosII_standard.v. 3. Added symbol to main.bdf. 4. Added SOPC pins as determined by symbol, i.e. ddr2_deva*. 5. Added hsmb_d[3..0] pins (as output for my testing). 6. Built design, takes ~15-20 minutes. I created an instance of the 'simple_socket_server' in NIOS-II and for the most part worked just fine. Still a long way to go for my final application. For further modifications: 1. Modify the CPU in SOPC builder 2. Generate cpu 3. Modify stratixIII_3sl150_dev_niosII_standard.v, if necessary, with new pin assignments. I used TextPad on Windows. 4. Regenerate symbol file from stratixIII_3sl150_dev_niosII_standard.v. 5. Update symbol for stratixIII_3sl150_dev_niosII_standard in schematic. 6. Rebuild design, takes ~15-20 minutes. I know, seems like a pain, and it is, but it worked, for now until I can find something easier. I tried adding the symbol stratixIII_3sl150_ dev_niosII_standard_sopc, but ran into problems when building. Thanks, /david
