Pin Delay information, Cyclone V SE, UBGA672
- 1 year ago
If the device handbook does not include this information or the IBIS file, it may be because FPGAs are completely customizable and the delay may be different depending on the design. You probably want to go through the EMIF documentation here to know what you need to do: https://www.intel.com/content/www/us/en/docs/programmable/683385/17-0/ddr2-and-ddr3-sdram-board-design-guidelines.html
You probably want the IBIS model so you can perform a board simulation: https://www.intel.com/content/www/us/en/content-details/674909/cyclone-v-ibis-models-zip.html?wapkw=cyclone%20v%20ibis%20models
- khacker1 year ago
Hello. No, it's not a simulation. I want to create a PCB layout with exact length matching, especially for the DDR-bus.
I need the pin/package lengths (i.e. the respective distance of a signal from the die to the ball) so that I can take these differences into account when matching from the solder pad onwards.
Best regards, Klaus- sstrell1 year ago
Yes but you should be performing a board simulation using the IBIS model to have an accurate guide of what lengths you should be using on your board to guarantee timing and signal integrity.
- khacker1 year ago
--> 5CSEBA2U23C8N
What I actually need is the total pin lengths of all the signal pins of "5CSEBA2U23C8N" (Cycone V SE FPGA).
Is this information part of an IBIS model?
Could it got extracted from IBIS? - khacker1 year ago
Hi.
I've imported this IIBS model to the Symbol, but not one pin got a pin delay information from it.
I also couldn't find any delay information within the *.ibs-files (search in a text reader).
Only hint to some DiffPins --> NA (see screen shot)
Maybe this parameter is not supported by this IBIS model?- sstrell1 year ago
This is not how IBIS models are used. If you are planning on designing and building a custom board, you should know how to perform a board sim.
