15 years agoPin Assignments -- less tedious way?
I have a Cyclone III 3c120 development board and am using the terASIC Data Conversion Card on the HSMC. Is there any better way of getting the pin assignments than doing them manually one by on...
15 years ago --- Quote Start --- i've run in to the same problems with transceiver assignments. at the moment i use the crude work around of commenting things in and out as needed --- Quote End --- Ok, thanks. If I get a better technique working, I'll post it to the forum. Cheers, Dave
