17 years agoPCIe negotiated as x1 instead of x8
Hi, I have configured the PCIe megacore on Stratix II GX development kit for 8 lanes but when I plug it into the x16 slot of my PC (Dell Optiplex 775) it is configured only as a single lane devi...
17 years agoNo! Whoops! I looked too quickly at the board schematic (for the wrong board, the Arria GX, to boot) and mixed up PERSTN and PRSTN. If A1 and B48 are connected than your board is at least being represented to the computer as x8 compatible, and so the problem exists elsewhere. Unfortunately I have no idea. I knew the solution above would be a stretch, that you probably had it configured correctly. Something is going wrong during link initialization & training... maybe the test out signals can help you. There are a ton of outputs there that can be used to diagnose physical lane errors, based on training sequences and ltssm states.
