10 years agoPCIE interface fails in Cyclone IV GX DevKit
I have configured the FPGA Cyclone IV GX (Cyclone IV GX Dev Kit) with PCIE firmware example from this site: http://www.alterawiki.com/wiki/pci_express_in_qsys_example_designs The cpld and flash me...
10 years agoHi Bob, ok I will do it.
I am reading the PCI Express Hard IP documentation to learn some about these signals that I have to check. The signal tap instance that comes with the reference design has the 'core_clk_out' as the sampling clock and because this clock is not being generated, nothing was sampled. I will replace this clock with a PLL output clock. Leds on the board are indicating that FPGA is active after the reset is deasserted. Thank you for your help!
