PCIe hard IP simulation on Xcelium
- 3 years ago
Hi Binu,
I have review the case with our Simulation Expert, unfortunately we do not support "xrun" utility, (though we do have xrun support in our roadmap).
this utility might be causing errors while compiling the libraries.
For now, we do support the multi-step flow where we compile the files first into designated libraries (using xmvlog), elaborate using xmelab and simulate using xmsim.
You can refer to any of our generated Xcelium scripts to see the commands, To generate the simulation scripts in Quartus click Tools -> Generate Simulator Setup Script for IP …
this option will generate several folders, you can open the xcelium folder to see the xcelium_setup.sh
(more info in this section from our documentation 1.5.3.2. Scripting IP Simulation)
here you can see how to use and source the generated script in the link below, in case you decide to use the generated script.
5.2. Sourcing Cadence Xcelium Simulator Setup Scripts
Alternately, you can run quartus eda simulation library compiler to generate xcelium script to compile the libraries.
Example , Here’s the command to generate xcelium script to compile Stratix 10 libraries for verilog:
quartus_sh --simlib_comp -tool xcelium -language verilog -family stratix10 -gen_only -cmd_file cmp.sh
(cmp.sh will contain the commands)
Regards,Wincent_Intel
Hi Binu,
I suggest you to regenerate a clean project and try it again.
Yes you can try to run https://www.intel.com/content/www/us/en/docs/programmable/683870/22-4/sourcing-cadence-simulator-setup-scripts.html
And see if you able to get it or not.
Wincent_Intel
Hi Wincent,
I do not want to use the approach of sourcing of generated script as this does not fit into our simulation environment setup.
Hence calling the 'xrun' commands directly on the files. Do you know or can you check with the development team if 'xrun' call on the files (listed in xcelium_files.tcl) is a valid and Intel supported approach?
Binu
- Wincent_Altera3 years ago
Hi Binu,
