17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question.
By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II catching packages from the Ethernet interface (RJ-45). The first problem is I don't have any example for that board which uses the RJ-45 interface, 'cause I don't have the SFP conector yet. I want to adapt this core here (Small TSE MAC Ethernet Example - http://nioswiki.jot.com/small%20tse%20mac%20ethernet%20example) to use it in a PCIe Dev Kit with Stratix II GX. But it requires a SSRAM, but the Stratix II GX don't use this kind of memory. Can any one here help me? Thanks!47 Replies
Thank you for your quick reply!
Yes, i've reset phy core; i'm using the design "cycloneIII_3c120_dev_niosII_standard" that i found on altera website. - Altera_Forum
You should check that the gtx clock is fed correctly, that the RGMII interface is properly constrained and that there are no timing violations reported.
I would also suggest to connect a SignalTap probe to the RGMII interface and see if the TSE is trying to send anything there. - Altera_Forum
Daixiwen, i have a stratix 2 gx with uclinux on it. I can't get more than 30 Mbits/sec.
How can i get more speed? - Altera_Forum
There is a thread on that subject in the Nios forum but unfortunately it seems to be offline right now.
There is a design example on Altera's web site about improving the TCP/IP performance, and it's a good place to start. - Altera_Forum
Hey
Can someone please upload the *.c+h files if simple socket server that works with the design example that sophie uploaded? it will be very helpfull. thank u - Altera_Forum
anybody used sfp modules?
yes. sfp+, actually.
