17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoHow did you downloaded the uClinux in PCIe Dev Kit, SIIGX?
I have got this error: --- Quote Start --- Can't configure device. Expected JTAG ID code 0x020E30DD for device 1, but found JTAG ID code 0x020A20DD. --- Quote End --- That error occurs when I try to use Sophie's sof. When I use mine, I can download the uClinux as well. I don't know if this problem is because time I'm working in a application with pcap lib. I had problem when I tried to compile this lib in uClinux-dist, but, with a friend help, I fixed it. I had ported this application to uClinux in a 1C20: http://www.tcpdump.org/sniffex.c If you post your design, I can create a image of uClinux with this application. We can do this application, mrbietola... I will try to write a file in DDR and send to a outside database...
