17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agohi Lerxt,i have ported uclinux on stratix II GX, for the TSE i utilized the Tripple speed Ethernet Driver (experimental) because the other driver (by SLS) don't work for me (i get kernel panic) i'm configuring the flash now to boot uclinux from it.
To configure flash, i have founded an interesting example on the nioswiki, the example is called "udp offload packet" and it use the same board we have. http://www.nioswiki.com/exampledesigns/nios2udpoffloadexample we would do an application on uclinux that brings data from ddr and trasmits over ethernet possibly in Gbit mode (GMII or SGMII interface). In uclinux i think is only supported MII interface (10/100 Mbit/s). Do you have any experience doing ethernet application on uclinux?
