17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoI have got the same thing, Sophie and mrbietola...
"Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4)" The RX led has blinked, but TX hasn't. Other problem in this board is the Spansion S29GL512N Memory. Altera don't provide the the file to use correctly this memory. I know TSE Megacore stores the MAC andress there (Stratix II GX PCI Express Development Board Reference Manual, page 2-16). Because that I set the a static IP to Simple Socket Server. I have worked in a 1c20 with uClinux for while. I am going to port uClinux to PCIe Dev Kit and I going to try to run ftp there. If it works, I will post the image and ptf files here.
