17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agohi, i get things working in MII mode (100 Mbit)
i think for the GMII mode you should run .sdc and .tcl file with right ethernet constraints (i found it on alteraforum and adapted to 100 Mbit) you should add a pll to get 125 MHz to gtx_clock and add 90 degree phase shifting for the tx clock going to TSE mac and least but not last, assure when you ping the pc from the board, that you have firewall disabled! (i saw tx led blinking but no data arrived to pc) bye
