17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoHi Sophie,
That sounds really good. You have no success with telnet, but can you ping it? Also, can you sniff if any messages are sent from your board to the network when it comes up using WireShark or something? Does it even try to get an IP address using DHCP, or does it default to your hardcoded IP address? If you could post your project (Quartus, not Nios II project), maybe Lerxt and I could take a look, and play around with that (since neither of us can get our .elf to work properly with our .sof) JB
