17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoHi Lerxt,
No, I still have not had success porting the Simple Socket Server over. I am now at the same stage you were. I am able to program the .sof file to the device, but then when I try to download the simple_socket_server.elf file, I get: Using cable "USB-Blaster [USB-0]", device 2, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused I will let you know if I get anything. JB
