17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoHi Lerxt/Sophie,
I am also trying to do something similar to you guys. Lerxt: When I try to open your core.zip project in Quartus II (8.0) I get many errors related to eth_ocm_0 not being found. Specifically, when I try to do a Full Compilation I get: Error (10054): Verilog HDL File I/O error at eth_ocm.v(247): can't open Verilog Design File "eth_defines.v" Error (10054): Verilog HDL File I/O error at eth_ocm.v(248): can't open Verilog Design File "timescale.v" Error (10112): Ignored design unit "eth_ocm" at eth_ocm.v(251) due to previous errors Also, when I open up SOPC, the eth_ocm_0 module is highlighted in red, and says "Missing Module" next to it. Do you know anything about this? Thanks, JB
