17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoThanks, Sophie, now I am using the PIN_A20 in the TSE core, and PIN_H7 to the rest of design.
The only thing that Reference Manual says about the 100 MHz clock is they are localized in pins 4 and 5. But where is the pin 4 and 5? But it didn't work yet. I don't know how I reset the PHY, because I don't have any pin for it. When I set the simple socket server to use the DHCP, the Marvell PHY waits a reset =/ Which modification I have to do to reset PHY in my design, jakobjones?
