17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoAt this point I would do two things:
1 - Check the timing analysis. Is the Ethernet interface fully constrained? 2 - Make sure the simple socket server example is set to use DHCP. Use a packet sniffer like wireshark to see if the board is sending anything out on the wire at startup. Jake
