17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years agoI would like to start this by thanking for your response,Vizziee.
I'm trying to use the PCIe Dev Kit to capture Ethernet packages to process it in the NiosII using 1 GBs' interface, via RJ-45, and in the future using the optical interface. But, to make it in that board I think that I need this basic architecture: NiosII -> DDR2 -> SGDMA -> TSE -> (RJ-45 or SPF) In that board I have those memories: MT47H32M16CC-3 32Mx16 and a MT47H64M8CB-3 32Mx8. In Cyclone II Dev Kit is more simple, because I can use a Cypress SRAM, that is more simple than the these ones. I made what you said and discovered the "Verify failed between address" was in DDR2 memory section. I'm using the an517 tutorial, making the modifications to PCIe Dev Kit, and now I have this problem: --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 2, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused --- Quote End --- PS: I didn't connect the TSE module yet, I'm just trying to configure the DDR2 correctly first. Altera says this abou this erro: http://www.altera.com/support/kdb/solutions/rd07272007_849.html But I realy don't know...
