17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years ago --- Quote Start --- Hi folks. I guess I'm in the right way. I had to change the Cypress SRAM memory by a DDR2. Now the problem is how to configure the DDR2 on PCIe Dev Kit... I downloaded the software in the FPGA, but i tried to download the Simple Socket Server example, but I couldn't. It showed this menssage: "Verify failed between address" If I fix that problem, I will post the project here... --- Quote End --- When you get "Verify failed between address" message, just check the address range in that. You can then find out exactly which component is not working (though this error usually indicates problem with boot_flash).
