17 years agoPCIe Dev Kit Stratix II GX and the TSE MegaCore
Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II ...
17 years ago --- Quote Start --- Hi everyone, I'm new here and have a question. By the way, it's my first adventure with complex cores and FPGA's, I used to programming in ARM before that. I want to run a aplication on Nios II catching packages from the Ethernet interface (RJ-45). The first problem is I don't have any example for that board which uses the RJ-45 interface, 'cause I don't have the SFP conector yet. I want to adapt this core here (Small TSE MAC Ethernet Example - http://nioswiki.jot.com/small%20tse%20mac%20ethernet%20example) to use it in a PCIe Dev Kit with Stratix II GX. But it requires a SSRAM, but the Stratix II GX don't use this kind of memory. Can any one here help me? Thanks! --- Quote End --- I suggest you use simple socket server (depending upon your application, you can also convert it to a "simple socket client") example as your apllication requires reception of data only. Can you write what exactly that SSRAM doing in this example? If it is an external RAM, you can always replace it with any other RAM that is available to you.
